Small Block Chevy
PARTS FOR SALE
EDELBROCK Victor Jr Tunnel Ram
NEW- £150
Hat Adapter For Above
NEW- £50
Full Set of MANLEY Titanium Retainers for 10 Degree Locks
Part No. 23658 (Spring OD 1.550, ID .705)
NEW- £80
1x CRANE Aluminium Roller Rocker Arm Part No. 11750-1
NEW– £10
1x MANLEY Roller Timing Chain Set with Torrington Thrust Bearings
NEW- £40
TCI Powerglide Anodised Aluminium Scatter Shield
MINT- £40
1x Complete Carb to Pan Small Block Chevy Race Motor
Engine Contents:
4 Bolt Main 010 Block with Oil Restrictor Kit (O-Ringed)
DART Sportsman II 64cc Iron Heads
Balanced and Tufftried Crank
CHILDS and ALBERT Ali Rods (40 Runs)
Billet Ali and Stainless Steel Damper (Non SFI)
TRW 12.5 to 1 Forged Pistons
CHILDS and ALBERT 0-Gap Rings (20 Runs)
LUNATI Roller Cam and Roller Lifters (Big, Custom Nitrous Grind)
MANLEY Race Roller Timing Chain Set with Torrington Thrust Bearing
MANLEY Stainless Inlet Valves
MANLEY Inconel Exhaust Valves
MANLEY Titanium Retainers and 10 Degree Locks and Lash Caps
CROWER Vasco Jet Valve Springs (20 Runs)
CRANE Roller Rocker Arms and 3/8 Screw In Studs (ARP)
JOMAR Stud Girdles
MANLEY Push Rod Guide Plates and 3/8 Push Rods
MELLING High Volume Oil Pump
MOROSO Oil Pan
BRODIX Ali Valve Covers with Custom Evac System
EDELBROCK Victor Jr Manifold
HOLLEY 4150 850 CFM Carb
NOS Pro Shot Fogger (Custom Built to Manifold)
Solid Copper Head Gaskets (60 thou)
HOLLEY Blue Top Pump and Reg
CHAMPION V4C Race Plugs
CHAMPION BL60Y Warm Up Plugs
MALLORY Unilite Dizzy
Custom Made Plug Leads (8.5)
Engine can be seen running, comes with complete build literature and component literature. Engine runs no water.
Runs 9.1 – 145 MPH No Nitrous
Runs 8.1 – 166 MPH With Nitrous
This was achieved in 1650lbs Comp Altered using a 2 Speed Powerglide with 4.11 Gear Ratio. Engine has scope for further performance development. As is the engine fires on the button, requires no setting up or dialling in, it runs without fault all the way through to its 9200RPM design limit. (MSD Limited to 8900RPM)
I am asking for £3500 for this complete engine, it would be a real shame to split this proven combination, but obviously if needs be we will split the engine up.
Please do not hesitate to contact us with any questions you may have, or any deal you want to do.
View a run of Gonzo @ Santa Pod:
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/9Oz4a6JSkwc&re ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/9Oz4a6JSkwc&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/youtube]
Or Here...
http://www.youtube.com/watch?v=9Oz4a6JSkwc
Email: ClairesCornerShop@googlemail.com
PipHigham@hotmail.com
Moblie: Alan 07803134974
Ian 01617939742
PARTS FOR SALE
NEW- £150
NEW- £50
NEW- £80
NEW– £10
NEW- £40
MINT- £40
Engine Contents:
JOMAR Stud Girdles
MOROSO Oil Pan
Or Here...
Ian 01617939742
