RWYB Scimitar roller
Reliant Scimitar 5A? heavily modified NO V5 or VIN PLATE
It has been built as a RWYB or track car, the front has been made removable as a one piece (it doesn't actually flip) the dash and bulkhead have been made in steel, it was built as an auto and has top hung pedals in place with mountings for an accelerator cable and master cylinder, the front has mounts for a front engine plate and the transmission tunnel has been made in ally to cover a fair sized auto box
The steering column is non original it has two UJ's and is connected to a rack which is well mounted
The original rear axle is in place with watts linkage and four link
all callipers are in place albeit the pipework has been cut and removed, there is provision for a handbrake
The doors and bonnet are there, the door hinges are ready to bolt doors to and latches are in place and working
There are no door tops, there is no glass at all
The front floor is in steel but from the centre line there is no floor or rear bulkhead
No fuel tank
4 x Ally wheels are included although the tyres are shot, they are Toyo Proxy's as well but split now
It has a good rollcage, it has a drivers door bar but nothing going forward so may need additional tubes adding but what's there is very good
pics available just cant load them at the moment
car is in swindon wiltshire offers around £400
call/text 07588 772590 and I will send pics
No fuel tank
