Clearing out the cupboards
Mallory Comp 9000 electronic dizzy (new?) £90
New Crower hydraulic street strip cam (460 lift ) and lifters £125
New Pioneer SBC rod bolts £25
New Morosso stud girdle SBC £50
New Mr Gasket 7/16 rocker studs p/n 1074 £35
New Mr Gasket sure lock rocker arm nuts p/n 921 (slightly soiled ) £20
New Mr Gasket Cam button spacer sbc p/n 1180 and offset cam bushings p/n 85 £15
New Miloden sbc oil pump deflector plate £5
New Manley SBC front timing cover seal £5
New Crane aluminium hard coat retainers p/n 99606 £20 (packaging damaged)
used Holley regulator £10
SBC mini starter listing as used but as new £70
32 spline funny car drive shaft 20 inch long £70
16 spline funny car drive shaft 27 inch long £70
16 spline coupling sleeve £40 each 2 available
16 spline male couplers £50 each 2 available (1 x long 1 x short)
Aluminium drive shaft collars £20 per pair
Ford 390-428 rear main seals believed to also fit early Donovan 417 blocks 5 sets £20 for all
Blower belts
New RCD 1543 - 13.9 - 65 HT £100
Used 1694 - 14-65 £60 each (1 slighrtly marked £40)
Silver DJ 426 hemi diaper rough condition £40
All prices plus postage at cost or could take to Dragstalgia
Tel 01624 897737 or 0764 425619
Richard Moor
Blower belts
Richard Moor
