Early Spring Clean :-
Pair 17" x 2.5" wire front wheels - Pop Spindle £350.00
Chrysler 8 3/4" rear axle, fully floating with gears, 35 spline spool, brakes and calipers £700.00
Bare Chrysler 8 3/4" case (no ends) £75.00
Pair 40 spline drive plates (Strange) 5 1/2" PCD new £160.00
Pair Dart 426 Hemi cast "Water Heads", 1/2" stud with new guides complete with valves etc £850.00
Magnesium 426 Hemi 16 bolt blower manifold to suit heads £200.00
Pair short Zoomie headers to suit Dart Hemi Heads £75.00
Pair Long Zoomie headers to suit Dart Hemi Heads £75.00
Set .904" 426 Hemi Roller lifters £200.00
Odd .904" roller lifters (pairs) £25.00/pr
Fram oil Filter head with 2 new filters -12 in/out £80.00
Set 426 Intake Rockers (slipper style - aftermarket) £200.00
9 x 426 Exhaust Rockers (slipper style - stock) £180.00
Pair Cast ally Rocker breathers (threaded outlet) £50.00
13.9mm Blower pulley 29 tooth £40.00
13.9mm Blower pulley 37 tooth £45.00
13.9mm Blower pulley 40 tooth £45.00
13.9mm Blower pulley 41 tooth £45.00
Blower idler tensioner magnesium 2.5" wide x 4.5" Dia £45.00
Blower idler tensioner aluminium 2.5" wide x 4.5" Dia £40.00
Blower restraint for 14/71 out of date but good condition (no bag) £50.00
Lenco Direct drive / reverser fine spline input & output £450.00
Input shaft 1 3/8" 10 spline to fine spline 8 1/4" long £75.00
Input shaft 1 3/8" 10 spline to fine spline 8 3/4" long £75.00
L&T 10" 6 stand Titanium glide clutch cover & Donut no facings, old but still tags OK £500.00
16 spline driveshaft 17" long £75.00
16 spline driveshaft 14" long £75.00
16 spline driveshaft coupler (sleeve) £25.00
Coupler 16 spline female to 20 spline Male £25.00
Airhart single circuit Brake Master cylinder (New) £75.00
Stroud fireproof chute packs (Black) used £25.00 ea.
Contact Paul on 07833 467712
