 #40175  by shasta
With the help of my niece a couple of weeks ago, we had another go at starting the bike with the new beefier starter handle fitted. Firstly we found fuel was not getting to the rear carbs so a new fuel tap bracket was made to get it lower than the tank outlet. Spinning it over we had a couple of coughs and flames from the front exhausts as the fuel ignited but no start,so the ignition timing needs to be gone over again from the start to check that it's set up correctly. We also noticed that the belt tensioner had bent the inner engine plate allowing the belt to become slack. A new arrangement with an outrigger support is now being made.......plenty of time on my hands to get round to do stuff like this. Unfortunately I don't think Dragstalgia will be taking place in July which has been the target we have been working towards. Hope everyone out there keeps well and see you at the strip when all this is over!!
 #40177  by shasta
Time spent around the shed the other day has seen the new primary belt tensioner nearly finished, just might put a couple of lightening holes in the plates.
 #40184  by shasta
New primary belt tensioner finished and fitting. Did put in a couple of lightening holes... bound to make a lot of difference on this big lump!Photos show old set-up, lightened plates and the new unit in place. Now to check over that engine timing and ignition timing again, which will hopefully show up why it's not roaring into life! Keep safe.
Old set-up
Old set-up
Plates with lightening holes
All fitted
All fitted
New tensioner in place
 #40188  by shasta
Latest work has been setting up the engines relative to each over to get the ignition timing correct. I made a new TDC setting tool so that I can get the engines exactly at TDC which is not that simple as there are no timing marks on these cranks. So, put the rear engine No. 4 cylinder at TDC on the firing stroke, then set No.1 cylinder the same, on the front engine; then turn the front engine backwards 90 degrees, pop on the connecting drive belt, set the belt tensioner and then turn the engines so that No.1 cylinder on the front engine is at 40 degrees BTDC. Then turn the distributor by hand until the plug fires on that cylinder. Pop on the distributor drive belt and it should all be hunky dory. Simples! Except the timing disc only fits on the right hand end of the cranks, and you can only turn the engines over on the left-hand side but got there in the end. So petrol in (again), battery connected (again), chokes on (again) and spin the motors over...and the output drive sprocket in the starter shears (again!). Cue locking the shed door and going in for a beer, but hey, if these things were easy there would be loads of double-engined bikes still kicking around. Stay safe.
