 #40138  by shasta
Posted a video of the bike turning over for the first time. It has got the plugs out and the clutch dis-engaged but it's a start. Be attempting it again with the plugs in and if it spins over fast enough, I'll go for a start!
Video at https://youtu.be/E7LnnzPKNxk
 #40139  by NitroWars
Very nice, you've done a good job there. Thanks for posting and I am looking forward to the next instalment and seeing the bike back on the track.
 #40151  by shasta
First starter motor came to nowt! Even with 24 volts through it, would not turn the engines over. Borrowed a small hi-torque starter motor from a friend who took it off his small block Chevy. However after weeks making up an adaptor to fit my starter 'spider' and making a handle arrangement, it all came down to a big FA in the spinning the motor over department!! I can't risk putting 24 volts through his motor as he wants it back undamaged, so the hunt continues. Anyone got any big hi-torque starters around under a bench?
 #40154  by shasta
Now building a 6:1 reduction gearbox to fit on the current starter I have. This should obviously increase the torque 6 fold with a similar reduction in speed but it should only need to spin over a few turns to fire up!
Be back with the update in a few weeks!
 #40158  by shasta
The reduction gearbox I've been working on is nearly finished, just one spacer to make when all bolted up and some guards to go on to prevent any fingers getting lost!
Photos show the construction from the blank sprockets to the finished item. Sprockets and bearings from Simply Bearings, ali plate from Metal Supermarkets is Southampton all other bits out of scrap box.
Will be fitting unit to the starter motor and then it's fingers crossed again to see if it works to plan!
Sprockets as obtained
Plates before machining
Ready for putting together
More bits
More bits
some components
some components
All together
All together
Finished unit
Finished unit
